wnjj
Jul 01, 2019Explorer II
theoldwizard1 wrote:
While I have had to deal with failing lug nut "covers" I am not sure that is the OP problem. The bore where the stud is pressed into from the rear of the drum/rotor look too smooth. See how deep the knurling is on the stud. It looks almost gone on the bore. Loctite make a special adhesive just for something like this, Loctite 668 High Temp.
(My guess is that someone over torqued the nut to begin with and the knurling failed
Good drill bits, lifetime guarantee - Drill Hog 21 Pc Drill Bit Set w/Index
It’s tough to tell from the picture but I tend to agree. The lands on the hub look wide and flattened off and not pointed. It also looks like there could be small shavings in there.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
