edatlanta
Mar 17, 2016Explorer II
mchero wrote:
It's working normal. All the others do it as well, it's just that the owners don't know it.
Their is a rubber boot between the soap dispenser and the inner drum. This boot has a water trap in it. When the dryer mode starts you will hear the water valve open for about one to two seconds to put some water in that trap preventing hot air from escaping thru the soap dispenser.
Same EXACT thing happed to me. I was drying clothes with the water shut off. while drying I noticed hot air escaping from the detergent dispenser. I turned off the dryer, turned on the water & herd the 2 second fill B4 drying cycle.
Their are three "ports" between the outside world and that inner drum;
The blower/heater assembly that sits on the top of the outer drum.
The rubber boot in the upper rear that vents hot air out the back to the dryer hose....Note that this boot can get plugged up with lint.
The rubber boot/water trap located on the upper left front of the drum. At the start of the drying cycle a shot of water is dispensed into that boot creating a water trap that prevents heat from escaping out the soap dispenser.
Note that both hot & cold water must be on for a complete cycle. I have a leaking water valve on the hot side. Until I can get a replacement valve &I have just cold water on & I have to select cold only.
Funny seeing all the "mine does not do that" posts because both the Splendide 2000S and your 2100xc model do it. Others must have a different model! LOL
I have used my 2100XC for 5 1/2 years full time and I have wondered why there is always a shot of water before drying starts. Now I know!
Thank you.
