wa8yxm
Dec 14, 2020Explorer III
I will join the use the special connectors designed for the job chorus.
Avoid joining AL to CU if possible but if you must use the proper AL/CU or CU/Al connector for it is designed for the job.
Standard connectors not good for this. Corrosion will set in, resistance goes up and with a Stove or oven which are HIGH CURRENT devices.. bad things can happen (like fires)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
