I went for perfection with my solar setup and ran 4ga from the controller to the batteries and 10ga from the controller to the panels. It was a pain to do and more expensive and the end result is a setup where my batteries are at 100% within the first 2 hours of daylight. With a 10% current loss the 120 minutes of charge time would instead be 132 minutes. What did I gain in being at 100% by 10:00 AM versus being at 100% at 10:12 AM each day?
Appreciate too that the current carrying ability of wire is largely a function of the area of a cross section of the wire. Going from 4ga to 2ga wire size does not provide double the current capacity but rather an increase of about 59%. Conversely going using 4ga instead of 2ga decreases the current carrying ability of the wire by about 37%.
It seems that the manufacturers undersize the wiring for solar and the average RV owner oversizes the wiring to the same degree if not more.
