BFL13
Aug 06, 2014Explorer II
Yes just ground the second bank to the frame for the neg parallel link and connection to the "head" You now only need one positive wire to the "head" to be the parallel link and the connection there. You do need a fuse on that positive wire close to the batteries.
Yes to the above to have a switch so you can use the batteries as a four battery bank while camping but separate them for when not camping. Buy a small maintenance charger that stays at 13.4v (typical amount) to put on the second bank while the converter does the other bank when you have shore power. (If on solar for long periods of storage not camping you would need two separate solar maintainer sets )
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
