phurley's avatar
phurley
Spray Foam Sealant
The local RV repair shop uses Touch N Foam Home Seal for holes that didn't quite get filled at the manufacturer. Is there another brand that anyone can recommend? I can't get Touch N Foam Home Seal on Amazon and the local hardware store doesn't have it.
  • spadoctor wrote:
    great stull also has one now that repels bugs and rodents
    I've not seen that one, I'll look for it next time.
  • great stull also has one now that repels bugs and rodents
  • not just appropriate for the size of holes, for the effect that extreme swelling might be, pushing out side paneling, etc.
    bumpy
  • Great Stuff has several different products, the normal expanding (2x), a minimal expanding foam, and a 3x expanding foam, use the one appropriate for the size holes you have to fill.
  • there are at least two varieties, on that doesn't swell up quite as much.
    bumpy
  • If you use it, remember, that stuff swells up a lot bigger than you think.
  • I have been satisfied with Great Stuff from Home Depot to seal gaps at home and in our RV.
  • Check HERE.
    Not sure if it's approved for sale in California though...pretty nasty stuff if you read the MSDS sheets..and you know how California is with "dangerous" stuff....Dennis
    On edit: it appears it's available at KMart stores in both NorCal and SoCal..according to their website....Dennis
