Wolfman_Jacques's avatar
Oct 23, 2014
Spring Shackles
Had a spring shackle breaK last Winter while pulling into Catalina S.P. near Tucson. I was lucky to find a nearby axle place and bought a pair of shackles and bolts and was back in business in no time. The hardest thing was getting the nuts off. I recently decided to check out the other shackles for metal fatigue and boy it is a good thing I did. They were all stretched out and ready to break. Today I replaced them all. I suspect that this is a problem that is not unique to me, so I am surprised that it has received sUch little attention on this thread. My fifth wheel is pretty light but naturally it only has leaf springs but no shocks. I would think that without shocks the spring shackles take a good beating and metal fatigue would be a common problem. I would encourage everybody to check their shackles every 3 or 4 years.
  • ScottG wrote:
    The shackles and equalizers are normal wear items for trailers. Some of us installed wet bolts which allow us to grease these parts and the bushings as well.
    Good upgrade.
  • The shackles and equalizers are normal wear items for trailers. Some of us installed wet bolts which allow us to grease these parts and the bushings as well.
  • I had our 2007 travel trailer springs checked out this year by a truck axle shop. The bolt holes were slightly elongated but the plastic or nylon bushings were not in too bad of shape. Our TT does have shocks which I also replaced so maybe that does help minimize wear.
    Dick
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
