Joe417
Jan 10, 2017Explorer
I read,
Left and right camera inputs activated with turn signal switch
Rear camera and audio inputs controlled by reverse gear
Front camera has manual control
If the unit isn't getting a signal from the reverse gear switch and it takes some time to get it to reset to other inputs I would think it has a problem.
I would disconnect the camera control wires and see what it does.
If this issue is linked to on time, I would suspect software, whether a configuration setting or a software bug.
Good luck,
Good luck,
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
