dougrainer
Jan 11, 2017Nomad
Disconnect the Rearview Camera TRIGGER wire (Green wire). This is the wire connected to the back up (Reverse) switch wire. Then test. IF it continues the problem, you have a defective Radio. IF the problem goes away, then something must be making that Trigger wire HOT(12 volts). When this happens, can you pull over and see if the Reverse lights are ON? Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
