The_real_wild1
Dec 08, 2016Explorer
Can you hear the motor running each time when it moves? If not check the electrical plug. Sometimes they will corrode. There will be a pin on the linkage as well. You can take out the pin and disconnect the motor to check the step. After you disconnect it you should be able to move the step in and out easily by hand. If not you can spray the pivot points to free them up.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
