enblethen
Dec 09, 2016Nomad
Start over on problem!
I would suggest that you start by re-checking the grounds under the step. There should be two. They are in a bad place that can get corroded quickly. Corroded connections can cause voltage drop. You would be getting alittle higher voltage on shore power.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
