wa8yxm wrote:
Belive it or not I'm goping to recommend a Progressive Dynamics 9200P (P for Plug in model) they come with 20 amp plugs however (The neutral s turned 90 degrees)
Now a word of caution. Standard Lead Acid shoud be charged at around 30%C or Less
So a 100 amp hour battery charges at 30 amps or less a 220 amp hour GC-2 Pair or D-4 at around 65 amps Match the last two digits to the charge rate.
I don't see any Progressive Dynamics 9200 P series online, not even on PD's website. Where do you find them?
Though it would seem pretty easy to add your own plug.
Even the 9280 80A converter is rated at 1300W input power, so that should work fine on a 15A circuit, so shouldn't need a 20A plug.
