Grodyman's avatar
Grodyman
Stand Alone Charger
Hi all,
What is the best stand alone battery charger? I have had a couple of Shcumachers and I am really not impressed. Also, there seem to be several dozen Schumacher models, how the heck do you know which one to get, they all look pretty much the same?
Also, I am considering just buying a Progressive Dynamics PD9260 and using that as a stand alone charger.
Gman
    What are you using it for? Are you charging your RV's starter battery because you left the lights on all night, want a maintainer to keep your batteries charged in storage, or trying to charge your house battery bank as quickly as possible while you run the generator?
    My only charger is a 2A Battery Minder, which works fine, if slow. When I left my car headlights on all night and drained the battery so low that the dome lights were barely visible, I hooked up the Battery Minder for a couple days to charge the battery.
  • Gjac's avatar
    Gjac
    Explorer III
    If you are going to use it to charge 2 6v GC batteries in you RV I would get the Stanley 40 amp charger about $100 or if you can find an older B&D 40 amp charger. I bought my B&D for $50 when Stanley bought them out. If not the convertors that BFL13 showed are good options especially the 45 amp for $114. If you want it just for your cars any 10 amp charger will work, Stanley makes 10,15 and 25 amp one.
  • Do you really need a 60A charger ? You would save almost $50 by downsizing to the 45A model.
