- MEXICOWANDERERExplorerThat is a primary charging voltage. -- time limited. When proven good, the battery reaches full charge then loses it's surface charge the voltage algorithm can be used.
- S_DavisExplorer
pianotuna wrote:
S Davis wrote:
MEXICOWANDERER wrote:
Resize this......
A flooded battery can irreversibly sulfate it's way to death but show resting voltage as being "normal" full charge. Read nothing more or nothing less in your replies thank you :)
What causes this to happen?
Not being fully charged, often from too low a charging voltage.
Oh ok, my charger is charging at 14.75 Volts so that should not be an issue. - pianotunaNomad III
Resize this......
Not being fully charged, often from too low a charging voltage. - S_DavisExplorer
Resize this......
What causes this to happen? - MEXICOWANDERERExplorerResize this......
A flooded battery can irreversibly sulfate it's way to death but show resting voltage as being "normal" full charge. Read nothing more or nothing less in your replies thank you :) - S_DavisExplorerSo this ARB 50 quart frig is pretty efficient, it ran for 96 hours in 70-80 degree temperatures set to 34 degrees and pulled the two Trojans T105s down to 12.68 volts. So less than 10%. I let them rest for about 24 hours before checking the voltage.
- RJsfishinExplorerI use a loaded test, tv and 1 lite on, 11.9v time io recharge.
S Davis wrote:
No harm at this measurement.
I am using a pair of Trojan T105s to power a ARB 50 quart frig, I leave for three days with them fully charged. They don’t seem to be being drawn down much, they started fully charged at 12.86 volts and only went down to 12.68 volts.- pianotunaNomad IIIBetter to turn on a 1 amp load for 10 minutes.
- BFL13Explorer IIThe 15 min disconnect trick sounds about right to me. If you note how much it goes up in the first 15 min, you can just count that in right off without disconnecting.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
