wa8yxm
Mar 14, 2014Explorer III
In a proper alignment it should not be necessary to pull the steering wheel, The adjustments are all UNDER the chassis.
There are several things that can cause the symptoms you cite.
Alignment is Suspect #1
Tire inflation.. Get the rig weighed, 4 corner and make sure the tires, epically the FRONT tires are properly inflated for the load they are holding up. NOTE that the inflation may be different on each side.
Brakes, if one is dragging...
Steering stablizers: Improperly adjsuted.
Damage to frame
Rear suspension/alignment.
Wind, road slope, and more.
Damage to frame
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
