We_Cant_Wait
Mar 14, 2014Explorer
As little as being off 3-4lbs in the air pressure on the front tires will make a difference in steering. Also there will be a natural tendency for a little pull to the right from the crown in the road, but this should not require a lot of constant left pressure on the steering. What I've done to help reduce the road crown pull is add about 3-4lbs more to the right front, then the left, but still keeping it within the pressure requirements based on the weighing weight of the front tire.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
