jodeb720
Feb 03, 2018Explorer
I have the bosch as well.
I live in Los Angeles, so I don't have the hard water problem other allude to.
Mine is exterior mounted; however, it's using the same flue path as the original water heater used before I replaced it.
As others have stated, you can't run the water slowly (from my own observation, the heated water exceeds the hi limit cut out and then turns off the burner until it's cooled back down sufficiently).
This problem applies to flow restricted shower head(s) as well.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
