Gdetrailer
Feb 04, 2018Explorer III
MEXICOWANDERER wrote:
- This would apply to stuff that has tires so I do not feel guilty asking
- First of all incoming water temp would average 45F at the coldest
- This would be an LPG unit
- Must demand water heaters be protected against "the elements"? The piezo ignitor being the issue
- No danger of freezing
- Need enough hot water for shower or dishwashing, not simultaneously
- I've seen several economy models. I am suspicious until proven otherwise
- Lime and scale buildup is a concern. Water harder than a whoopee lady's heart
- We have Bosch heaters
- What is your idea of the recommended Delta T of 70F?
70F Delta T might be obtainable provided the GPM is low enough.
Bosch Therm 830ES can be mounted outdoors provided you buy an outdoor mounting kit which is not included.
Bosch Therm830 specs
Has 35F rise for 8.3 GPM, 55F rise for 5.3 GPM, no spec on 70F rise and min draw required is .5 GPM.
Will need good propane supply, 175K BTU burner input will most likely require replumbing the gas line from 1/2" to 3/4 and upsizing your propane regulator and possibly tanks to handle that draw.
Efficiency, is a measly 82% so your not going to save much if any on propane costs.
This model does require 120V AC to operate, at one time they did have one that used drycells...
Weighs in at a whopping 67 lbs and about 18W x 32H x 11 deep..
At $1250 US, it isn't cheap and that does not include the option outdoor kit..
Therm830 at Amazon
We looked at demand water heaters a few years back and the Home Depot sales guy actually dissuaded us from considering them.. Too many potential issues..
#1 cost. They are insanely expensive compared to conventional tank systems.
#2 Variable water temps according to water flow
#3 Min water flow of .5 GPM just to start the burner.
#4 Re plumb 15 ft of gas line from 3/8" to 3/4"
#5 Scale/lime buildup (we have very hard well water and even with a softener faucets still get build up).
#6 Requires periodic Scale/Lime cleaning.
#7 multiple taps in use at one time requires upsizing unit which is costly.
#8 Hot/cold/hot/cold/hot/cold endless cycle if you are not drawing enough water and or using well or water pump setup.
#9 Repairs may be insanely expensive and or parts not available making replacement the only option in many cases..
#10 required upsizing our exhaust flue from 3" to 5", adding yet another huge expense in double wall vent pipe.
#11 Required yet another re-plumbing of the water supply lines.
We opted for another tank system instead.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
