Grodyman
Dec 03, 2014Explorer
Golden_HVAC wrote:
Chances are that if you buy the 135 watt, they will fit in a area on your roof easy, like between the roof vents and sidewall. The 270 watt probably will only fit in one location on the roof, and take up a huge chunk of real estate. Or might not fit at all, if there are roof vents going down the center, and the A/C is taking up some space, and the antenna is in the front. Do you have space for a 60" X 75" panel?
For my money, I would rather have three panels in the 100 - 135 watt range and 3 PWM controller at $14 each than a 270 watt panel and $125 controller.
SunElec.com
There are many places to look for solar panels on the internet, this is one of the lowest priced places that I have found. THey have advertized in HOme Power Magazine for many years, and are reliable.
Fred.
Does this mean they will charge the same but the high voltage panel setup will cost more and take up more space? Thanks
Gman
