newman_fulltime
Nov 30, 2014Explorer II
It could be anything from dirty connections to a sticking sail switch a bad ignihter a bad propane regulator at the tank and when the temps get down its freezing.
The best thing to do is check the simple things first
1 clean all connections
2 check your regulator see if its good
as if you can change parts you can do this
3 clean the igniter and check that your getting a good spark
4 make sure there is no blockage in the unit
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
