brulaz
Nov 30, 2014Explorer
newman fulltimer wrote:
It could be anything from dirty connections to a sticking sail switch a bad ignihter a bad propane regulator at the tank and when the temps get down its freezing.
The best thing to do is check the simple things first
1 clean all connections
2 check your regulator see if its good
as if you can change parts you can do this
3 clean the igniter and check that your getting a good spark
4 make sure there is no blockage in the unit
Yep , be sure to check the regulator.
My furnace was sensitve to low propane pressures and wouldn't start. The other appliances were fine. New regulator fixed it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
