mikestock
Mar 24, 2022Explorer
DougE wrote:
I would suggest connecting a ground wire from the chassis to the electrical ground at the supply plugin.
Hi Doug,
I did this early on and drove a 6' copper-clad rod into the ground and connected it to my chassis with #4 cable. Thought this would do the trick but not so. Right now I have a low output charger connected to the battery bank. Costco is selling a 100 watt panel with a controller for just under $100. Thinking about buying this and saving the $10/month I pay now
Seems more like a GFCI issue rather than overload. Maybe the OP can confirm if each outlet is on a separate GFCI breaker.
If this is the case there are at least 3 boxes and 6 breakers involved.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
