mikestock
Mar 24, 2022Explorer
Skibane wrote:
If you have a DMM capable of measuring AC voltage, you might use it to measure the voltage between the Neutral and Ground pins on an outlet.
Ideally, you shouldn't measure any voltage between them.
If you measure more than a few volts between them, the electrical hookup that feeds your RV doesn't have a proper bond between those two wires.
In a residence, those two wires are usually bonded together at the main disconnect switch or breaker box.
In a commercial building, the bonding location may be different - but it needs to be present.
I can check.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
