BurbMan
Mar 24, 2022Explorer III
GFCIs used to nuisance trip regularly,, the newer tech is very good and they don't trip unless there is a problem. When you say "GFCI breaker" can you be more specific? You can get a GFCI circuit breaker for the panel box that eliminates the need to install separate GFCI breakers. In that case if anyone on the circuit has a problem and the breaker trips the whole circuit is dead. If they are in fact individual outlets then I would change the outlet with a new GFCI. They do wear out. If your GFCI outlet is tripping after it's replaced then you have a problem with the coach electric.
If all you need to do is keep the battery charged, then get the solar panel and don't worry about plugging in.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
