CA_Traveler
Mar 25, 2022Explorer III
mikestock wrote:DO NOT BOND THE GROUND AND NEUTRAL. Doing so can cause voltage to be present on the RV frame because the neutral has voltage due to wiring loss back to the source in the pedestal or distrubution to the pedestal. Normally the neutral voltage is a few volts relative to the ground but it depends upon the wiring losses, loads, etc. Hence the bonding could creae a safety hazzard.
I wish I knew more. I have no intended access to the inside of the box. I have considered messing with the wiring in the box but don't really feel safe doing anything and maybe leaving a trap for someone else. If tieing the neutral with a ground outside the box I would try it.
The ground wire was added years as a safety wire years ago to procect against a short of appliance cases etc to the hot or neutral. It is not intended to carry any current except when there is a ground fault. Bonding to the upstream neutral can defeat it's safety intent.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
