mikestock
Mar 25, 2022Explorer
ScottG wrote:
Inconvenient truth, you have a ground fault.
Start unplugging things until it goes away (fridge, water heater, converter, etc.) and then FIX that item.
Do not circumvent safety or violate codes.
I know you probably haven't been following this. My neighbors are dealing with the same issues when I'm not even hooked up. I have done as you suggested several times over the years and find nothing. I hook everything up and walk away, actually not drawing anything except the inverter/charger. I may be ok for a day or a week but it would eventually trip out. My next-door neighbor in the lot and I watch out for each other. We both have the same problem on the same breaker or on different breakers.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
