dougrainer
Sep 10, 2017Nomad
Which ZONE is the Bedroom? Zone 2?
When you replace the sensor, WHERE is it going? Is it hanging from the roof Plenum area? Are you cutting and splicing? Where is the original sensor located?
When you remove the Zone 2 sensor, the temp reading defaults to the Zone 1 sensor. The Zone 1 can either be a remote sensor like you have for the bedroom or it can be the CCC2 Tstat. Which is it? You have a Zone 1 remote sensor also?
If the bedroom sensor is anyway in contac with any duct blowing cold air on it, it will not react correctly. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
