tommy24a's avatar
tommy24a
Strange issue
AC started to act up. 2006 Fleetwood Wilderness 5th wheel. The thermostat is marked as a RVP. Its a single stage for heat and cool. Purchased a honeywell RTH111b stat. Did some research on the wiring. At first the high fan came on. Unhooked the stat to make sure wiring was not loose. Put it back on. Nothing going on now. Took off again and tried to jumper the fan. Nothing
Waited a cpl hours and now was able to start high fan. Tried to now jumper the compressor..shuts fan off. Does not start compressor. Tried to jumper high fan again..nothing
Waited a cpl hours and jumped fan again and working. Not sure what the check is going on.
  • I guess I don't understand your logic. Your AC "Acted up". WHY would you think your Tstat was the problem? What was the problem with your AC? RARELY, does a wall tstat cause operational problems with a AC system. AS you have found out, Installing a NON RV Tstat is not that easy due to how the wiring differs from a Home system. Why did you not just get a new RVP tstat? Doug
  • If I take a multi meter across the blue and red wires I get the 12v. But the instructions I got say to not use the blue wire. I'm ??
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    RV T-stats and home ones as well often get their power (if electronic) from the FURNACE (Blue wires on an RV T-stat normally) not the A/C.
    Both home and RV rigs work like that
    HOWEVER
    Some RV types use replacable dry cell batteries.
    And the one I have. needs no power it's an old fashion bi-metal spring with contascts (Furnace only)
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
