ksg5000
Jan 11, 2018Explorer II
Most Kwikee step problems are associated with low battery and/or corroded ground wire (ground wire is exposed under the rig and is common issue - you need to disconnect - and clean the connections).
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
