pulsar
Jan 12, 2018Explorer
74williammorris wrote:
Until yesterday my Kwikee electric steps worked exactly as they were supposed to. Then for some unknown reason the steps stoped working when the motor home ignition is turned off but the steps work correctly when the ignition is turned on.
Can anyone tell me what to check?
Welcome to the forum.
When asking about issues with your rig, it would be helpful to include what rig you have. For example, 2015 Meridian.
With no additional information, I also believe that a switch has changed positions. Our steps have a switch, which when in the on position, will open and close the steps whenever the door is open or closed, regardless of the ignition switch. When the switch is in the off position, the steps will open the first time the door is opened and will remain out until the ignition is turned on, with the door closed, or the switch is turned on again and the door is closed.
Tom
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
