ksg5000
Jan 12, 2018Explorer II
Remember that when you turn your ignition on it puts both the chassis and coach batteries on line which would maximize power to the stairs which might overcome problem with one of your batteries or lousy ground. Suggest you take your rig down to tire/parts stores and have them test your batteries (it's free) and you should check/clean both your battery grounds and the ground wire to the stairs.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
