sansouci2's avatar
sansouci2
Strange Problem!!!
I am asking for help again for a strange problem. We own a 2003 40 foot
Monaco Executive with three slides. The other day we had snow, so we put the slides in. The next morning I put out one slide, and turned on the faucet, to make sure the water flowed freely. No water--water pump not working. Went to put out second slide--not working. The backup camera didn't work, the TV (which retracts into the ceiling when not in use) would not open up, and the gauges to show water level in the tanks--none of these worked. Checked the circuit breakers--all ok. Unplugged the 50 amp shore power and lights work fine, still have initial problem. Reset all breakers and everything works. Checked water pump and initial problem recurred. Reset breakers and problem still there, unplugged shore power and problem SOLVED. Elected NOT to try water pump again!!! Anyone know what the water pump has to do with the slides, backup camera ect.
Please help. The wife
  • Take them back for a check. They should be pro-rated. Sometimes they go bad. It may have been built on Tuesday after a 3 day weekend in the RV.
  • Just checked with Monaco, house batteries should be 4 6 volt batteries.
  • First step is ALWAYS inspect, clean, reattach battery connections. Check each battery individually with a DMM while they are disconnected. Better still, use a hygrometer for each cell. More likely an install issue than a bad battery but at this point everything is still on the table. I don't remember what the charging voltage should be, but I think it should be higher than 6.2 when it is actively charging a nearly full bank. Continue to gather data and report back.
  • If you turn on shore power, what happens? Does everything work but the water pump?
    With shore power on, the converter is supplying the 12 VDC and the batteries are basically just redundancy. So for now skip checking the specific gravity and all that and reconnect the shore line. Does the pump have 12 VDC? If it does then the pump is most likely bad. If there is no power to the pump, then you need to determine where the fuse or circuit breaker is and check for power on both sides of the fuse or CB.
    If this doesn't make sense to you, I would suggest a mobile tech. If you're in a campground, ask for a recommendation from the desk clerk. If you are at home check Google or the Yellow Pages for one.
    Extreme heat or cold can cause strange things to happen to electrical devices. Extreme cold can freeze water, could your pump be frozen? Is the pressure sensing switch on the motor bad? There are a lot of variables and that is where experience comes into play. If you don't have it call the moble tech.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
