joe0508ExplorerApr 12, 2015stripped nutI have a battery post that i cant loosen or tighten.It is loose and i cant tighten it down.Does anyone have any suggestions on what i need to do to get the bolt off?
jasultExplorerApr 12, 2015If the thing is loose turn it back and forth while getting screw driver under terminal to force up and off then just cut bolt
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
