pianotuna
May 29, 2016Nomad III
Hi,
High rate means they are perfect for folks such as myself who want to use an inverter. High rate, in some ways, is a meaningless term. Battery cells are rated to do 25 amps. Doing more than that causes voltage drop. That means the effective capacity gets lower pretty quickly.
I currently have 4 12 volt jars so I can do 100 amps without much voltage drop. But the microwave draws 170. It is not uncommon for me to see a load of 276 amps.
My bank is currently 556 amp-hours on 4 12 volt batteries in two banks wired in a balanced manner.
Since they are AGM batteries there is no need to equalize (from solar) and reconditioning will, I hope, be rare.
This telecom form of AGM is a "surplus acid" and ought to be treated much as if it were a flooded batter, i.e. do not go below 50%. They also need to be returned to 100% state of charge after each cycle as often as is humanly possible.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
