Nutinelse2do's avatar
Nutinelse2do
Suburban DSI Water Heater Q
Hey all
About 3 days the electric element on the wh quit working.
Started troubleshooting today.
There is an on/ off toggle switch which was frozen, so hubby took it out and the wires were burnt.
Cleaned wires up, tied them together, and the electric element works.
Question... Is that switch on the outside needed, since we have one inside to control both the electric and propane?
Hubby doesn’t see a logical reason for it, since we don’t winterize, and she’s never in storage.
Thanks in advance
  • Yours is not needed, just those of us with outside toggle only need it. It is handy to have outside for those that do winterize, or draining/flushing, so it can be shut off right there while you are working on it.
    Jerry
  • The switch is there because some OEM's do NOT install a inside switch. They expect YOU to go outside and turn the 120 on and off. Doug
  • It is not needed. It is an extra safety feature so you don’t turn on electric without water in the system
