cavie
Aug 15, 2019Explorer
There is no separate 12 volt fuse for the water heater. It is 120 or gas. The 12 volt circuitry is shared by the furnace and the fridge. maybe also the range hood. All these loads a very very small. There is a switch to turn the watwer heater on with gas. It will have a red light indicater. When you turn on the switch the red wight will come on then go out when the heater fires. If it does not light it will repeat this process 3 times. if it doesn't fire the red light will remain on. Find the switch and turn it on.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
