Son_of_Norway
Dec 12, 2015Explorer
Probably need to just replace the motor. The furnace is usually held down with screws at the corners. Disconnect the propane, electrical and vent then slide it out. Easy job on the workbench. Check the operation of the motor and blower on the bench to be sure about the source of the squeal. Good luck with the repair.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
