RoyB
Mar 30, 2017Explorer III
Mine get debris in the sail switch quite often since it is on the floor and we have animals wandering around... The fan is working to blow against the sail switch. In the event the fan shuts off the furnace propane feed needs to shut off as well so this sail switch is the feature that controls that...
The other problem may be no propane flow. You can check this by lighting up the stove top and see if it is burning a good blue color flame...
I have had problems on occasion where I opened the propane value to quickly and it has a pressure valve that will sometimes shut off when this happens resulting in no propane flow... Have to close the value again and wait a few seconds then open slowly which usually works then...
I have two propane tanks on my trailer so I have a d-ring that I move to the propane that is running. Then old me sometimes forgets what the d-ring means - to use or is this tank empty (I need to add a note) hehe... Gotta love getting old hehe...
Roy Ken
Roy Ken
