Boon_Docker
Mar 30, 2017Explorer III
kameronth wrote:
Thanks for the tips. I should add, we went camping last labor day and the furnace worked fine the first night, then stopped the second. My stove has good propane flow and so does my hot water heater which is further down the gas line than the furnace.
I'll check the limit switch tonight. Can the sail switch be cleaned without removing the unit?
If the fan is running like it should then the sail switch is OK and does not need cleaning.
