kameronth's avatar
kameronth
Suburban furnace - no spark issue
I have a 2010 Gulfstream TT. I tried searching the forums but majority of the issues I found were for no ignite problems.
My issue, I have no spark at all. The fan turns on under normal operation of the thermostat but the igniter does not attempt to spark - to simplify, it does not "click" at all.
Where/what should I check first? Should I remove the whole unit or are there test I can perform while it's still in place? The unit is a Suburban SF-xx - I'm not sure of the exact model number until I crack the unit open. Thanks.
  • I took off the electrical connections to both the sail switch and limit switch, cleaned the connections and put a little electrical grease on them. That did the trick. It ignites and blows hot. Thanks for the help!
