wa8yxm
Jan 14, 2014Explorer III
It can also be caused by impatience.. Many home furnaces when the burner cuts off the blower cuts off.. (Some newer ones it runs a bit longer)
RV furnaces, it runs a bit longer.. If it gets to 2 or 3 minutes you have a problem but at one minute I think you are ok.
IF the furnace has a "Blower only" mode (Which I would like to have) then it could be the T-Stat,, Otherwise it is the relay (or it's driver) on the control board that need attention. (New control board) If you have to put in a new board.
Consider Dinosaur Boards.. I really like the one I put in my Atwood.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
