wa8yxm
Apr 29, 2018Explorer III
Should it spin Generally no but under some conditions it might
Is it a problem if it does? Generally no
What problem can it cause...
If the electrode is STRAIGHT and it can also SLIDE inside the insulator (the porcelain part) then the gap could change, this is a problem
And if it has been bent to adjust the gap. likewise
Too much gap is a common problem.
