- chuckbearExplorer
trailrider wrote:
chuckbear wrote:
That lip won't keep out more than a drop of rain. It is there to allow the install of a bug shield, which hangs on the lip and is secured by a spring. The difference in length is probably to allow it to fit in the new furnace and not the old one. Chuck
The lip isn't there to "allow the install of a bug shield." The furnace manufacturers specify in their manuals to never block the exhaust or intake of the furnace with anything, including screens.
Wow, Most every RV supplier out there, including Amazon must be totally unaware of that, including us and most RV's we have seen.
http://www.amazon.com/JCJ-M-200-furnace-Outside-Fitting/dp/B0002UHWIG
Chuck - trailriderExplorer
The lip isn't there to "allow the install of a bug shield." The furnace manufacturers specify in their manuals to never block the exhaust or intake of the furnace with anything, including screens. - I would go with the old one. Keep the new for a year for if issues should change your mind.
- Dutch_12078Explorer III
vacuumbed wrote:
Perhaps I should install the old one.
The old one functionally has a "lip" as well to keep water runoff from being ingested. I think the full width lip on the new one does a better job of it though, compared to the beveled circular lip on the older style. - Chris_BryantExplorer IIIt's not really for rain as such- it's for the water running down the side of the rig. I would go ahead and install the lip even on the old one- it was pretty common- particularly on Airstream and round bodied coaches.
- vacuumbedExplorer
Perhaps I should install the old one. - chuckbearExplorerThat lip won't keep out more than a drop of rain. It is there to allow the install of a bug shield, which hangs on the lip and is secured by a spring. The difference in length is probably to allow it to fit in the new furnace and not the old one. Chuck
- tarnoldExplorerThe new lip will also help deflect the heat(rising) away from the coach.
- Chris_BryantExplorer IIThey sometimes put that lip on the older style as well- I would probably use the new one. To me it looks better- plus less wind resistance while driving :D
Good point about making sure the overlap is enough on the exhaust tube. - trailriderExplorerI see the exhaust tube is shorter on the new one. Make sure it's long enough to reach the furnace and overlap enough to seal.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
