joshuajim
Mar 18, 2018Explorer II
dougrainer wrote:
You disconnect the spark Electrode wire from the Control Board IgnitorPiezo tower. Turn off the LP or disconnect the 12 volt feed to the Gas Solenoid. Start the Furnace cycle. Use a LONG handle screwdriver with an insulated (wood/Fiberglass) handle and holdthe metal end of the screwdriver about 1/4 inch from the Piezo Tower spade. IF you get a strong spark your board is OK and your problem is either a bad electrode(not likely) or most common,anInsect nest on the burner and stopping the electrode gap for the spark. Doug
Thanks for your input. I pulled the cover off the burner/electrode area and the area is clean and the electrode is about 1/8" above it. Out here in the desert we don't have mud daubers. No mud. ??
