garyemunson
Oct 19, 2019Explorer II
When ours quit, I was pleasantly surprised to find that it had a hose for the gas line that was long enough to reconnect to the furnace once I got it out of the RV. They are in a steel "mounting sleeve" that they will slide out of. You will probably find you need a long screwdriver to reach in and bend back some part/s of the sleeve that binds on the furnace module. I think the installers are not too careful and will just jam the furnace units into the sleeve when building the RV bending things. I set in on some saw horses next to the RV and bought a 4 wire trailer plug/socket that came with enough attached wire to make a "pluggable" harness that left me with the furnace on the horses wired and gassed up. From that point, seeing what was wrong and fixing it was a breeze! Next time you are somewhere they sell trailer stuff, get a 4-wire plug. and add it to your junk bin for the inevitable time when the furnace acts up. In our case, I could hear the igniter but the gas valve was not opening. New board fixed it. Those little furnaces are things of beauty once you get them out where you can see and work on them!
