Tdroge42's avatar
Tdroge42
Suburban Furnace problem
I have a 2013 Puma 35qlb and my furnace won't do anything. I removed the furnace and found a white wire that had come unhooked. I'm not sure where it goes. I have 2 purple wires that go to the red wire on the furnace, a white wire that goes to the yellow wire on the furnace, and the 2 thermostat wires. I thought maybe the random white wire went with the other white wire and yellow wire but it still did nothing....
  • IF the white wire is LONG with a spade connector, then it may go to the Overtemp tstat. If that wire is NOT connected, the furnace will not do anything. Doug
  • The model is a sf 35. Thank you for the link. I will have to do a little reading on it
  • We would need to know the model of the furnace but the service manual can probably be found at
    http://bryantrv.com/docs.html#furnace
    you just have to figure out which model you have
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
