John_Joey
Oct 02, 2018Explorer
path1 wrote:
Op ...How hard first time inside? Big puzzle at first or pretty easy after staring at it awhile?...
Not bad at all. If all the electrical check out then it might be a plug jet. You'll have to get access to it which more then likely mean the gasket will fall apart on you.
Once you've done it a few times it only takes about 10-15 minutes to go through the furnace on a bench. Just remember you're dealing with something that's hot and needs to be in a well vented area.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
