Boozecamp's avatar
Boozecamp
Suburban Furnace stopped working
Furnace has been working fine up thru last night. This morning I get up and it's 35 outside, 43 inside, no wind, and furnace will not kick on. Checked the easy stuff first, Propane tank is half full, no breakers tripped. When I get home from work this evening, I'll check fuses, change over to the second propane tank which is full. Anything else I can do myself before calling the $$$ tech guy out for a house call? I did try cycling the system off, waited a few minutes, then turned it back on, no go! Is there a pilot light, or is it electronic ignition?
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Dec 27, 2024
