dougrainer
May 15, 2014Nomad
IF the furnace worked with the old tstat and NOW does not work with a NON RV tstat, then why suspect the furnace? The odds are, you have to do some more modification on your Hunter. The RV furnaces are not rocket science. The wall tstat just sends a 12 volt signal to the furnace. Fan operation and lighting are ALL controlled by the furnace, NOT the wall tstat. ALL the wall tstat does is send 1 signal to the furnace, then the furnace does everything else. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
