BFL13
Nov 30, 2017Explorer II
Does the "kick on" mean the blower starts but no heat comes on after that, or the blower does not even start?
Is there enough 12v voltage to run it after it ran a while the first time?
Why did you replace the thermostat--same thing before that? What thermostat did you use as a replacement?
The "swing" between set room temp and what the thermostat lets it get down to could be excessive with the wrong thermostat, so you might not be that low for the furnace to come on yet.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
